Lower Control Arm Bushing Replacement on 107?
380sl, 450sel
The lower control arm bushings on my 82 380sl are shot. So I'd like to replace them.
If I compress the spring and unfasten the shocks and connecting links, will removing the bushing bolts allow me to lower the control arm enough to remove the bushings -- or does the ball joint not have enough play to allow that?
Thanks in advance for the help.
SPONSOR
Answer
If you use the correct internal MB spring compressor, the answer is yes it can safely be done this way.
http://www.peachparts.com/Wikka/W123FrontSuspension
whunter@pelicanparts.com
