SL65 Whining Scratching steering noise in right turns
Hello, the dealership changed a high-pressure hose of the power steering 2.000 KM ago because it was leaking a little bit. Car has 40.000 KM.
Now the car makes a whining and scratching noise from the steering, but ONLY in RIGHT turns with a bigger steering angle and when the car is under "load" into the corner.
Any ideas? Pressure hose built in not correctly e.g. with tension?
Dealership says fluid level is o.k. and system bled correctly.
I hope it is not the Tandem Pump, but I think then the noise should be also there in left turns...
Any idea/help is appreciated. Thanks.
