Odd size tire damage 2010 4Matic?
Old Aug 19, 2013 | 07:37 PM
mikapen's Avatar
I don't know the mechanics of current 4Matic systems. I am wondering if the system could be damaged by running one worn tire with three new ones. Like one with 3/32" tread and three with 10/32".
I know some AWD systems can be ruined by this, but I don't think the 4Matic is susceptible.
For instance, if I damage a tire, it's 500 miles before I can find a replacement, and I mount a worn tire.
What will happen?
Old Sep 2, 2013 | 12:22 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
I think if its only 500 miles you're ok but if you plan to drive for longer than 500 miles then you should probably replace that 1 worn tire with a new one to bring the overall diameter of the 4 tires as close as possible.
You could cause extra wear on the 4matic system if one or two tires are more worn the others.
Old Sep 2, 2013 | 12:43 PM
mikapen's Avatar
Of course I would like to replace the mismatched tire, but what if I am driving cross country and I can't find a match for 1500 miles, what would happen to the 4Matic system?
Old Sep 2, 2013 | 12:47 PM
thenew3's Avatar
Probably just a little bit more wear to the 4matic system than normal.
Old Sep 11, 2013 | 11:11 AM
mikapen's Avatar
More specifically, on our 2010 ML BlueTec, (is it 3rd gen 4Matic?), what might wear more?
Is it only the differentials rotating slightly, or am I engaging/slipping clutches, or are the brakes repeatedly activating?
