Anyone have copies/numbers of tsb for motor mounts, brake noise, lack of acceleration
Old Sep 8, 2003 | 02:50 PM
Frank Wiesmann's Avatar
Thanks.
Old Sep 8, 2003 | 10:11 PM
RJC's Avatar
RJC
Various
Do a search, they're in there somewhere
Old Sep 8, 2003 | 10:17 PM
TSB copies
I found a copy of the engine control module update and also saw one for the motor mounts but can"t seem to find it again. If someone could post it or a link to it that would be great! Thanks!
Old Sep 9, 2003 | 02:30 PM
konigstiger's Avatar
'71 Pinto
Re: Anyone have copies/numbers of tsb for motor mounts, brake noise, lack of accelera
Originally posted by Frank Wiesmann
Thanks.
(1) Motor Mounts - E500 only. However, I had a slight ticking noise coming from the engine area and my dealer updated the mounts as a precaution. Actual noise was found to be the steerting rack mounting plate.
(2) Brake noise = P-B-42.46/27a, Hydraulic brake pump damper. Also, have them check the pump for leaks - https://mbworld.org/forums/showthrea...defective+seal
(3) Lack of acceleration (ALSO) intermittently hesitant at slow speeds (i.e.: parking lots - as if about to stall, hunts, loss of power) = P-B-07.00/28a, Engine Control Unit Software Update
FYI, other common problems:
(1) Steering wheel shimmy 50 mph plus = Balanced & rotated all four tires.
(2) Vehicle drifts right = Front & rear wheel alignment and, more importantly, left & right camber/caster kits (attached work order).
(3) Excessively loud cooling fan = Replaced fan assembly and blower fan. Still loud but not as often.
(4) Windshield wipers skip = Replaced defective wiper blades.
