Oil leak from ML320 (163)
Old Sep 5, 2013 | 04:23 PM
dubs1383's Avatar
Mercedes ML320
Hi guys,
Iv got an oil leak from near the oil filter housing which I'm sure is from the oil port, however iv noticed oil on the top part of the sump under the crank pulley on the opposite side.
Was wandering if you guys have had the oil make its way from one side to the other? As the crank pulley isn't broken up and it's near impossible for me to see any cracks in the engine casing made by the damper pulley as its too dark.
Any info would be great.
Old Oct 2, 2013 | 09:52 AM
stevenn11's Avatar
ml320
I have a oil leak on a ml320 1998 it looks like its behind the ac pump its motor oil any ideas
Old Oct 10, 2013 | 09:23 PM
NJProTech's Avatar
MANY
Under oil filter housing is a port for check oil
Pressure. These leak often. Best thing is clean engine and apply a white powder (foot powder). Let it show you where the leak is beginning from.
