Trouble with car
Mercedes Benz s430
Trouble with car
Hello I'm looking for some help on my Mercedes Benz s430 it's saying display defective ESP visit workshop and brake assist and the abs light is on but my brakes feel fine, and my car for some reason is really low to the ground only about 1inch separates the car from the ground. Is it possible to manually lift the car? Please someone help me out with this problem or any suggestions?
Hi! Most likely you just disconnected the batteries. All that you need just turn your steering wheel all the way to the right and after all the way to the left and push brake pedal and those malfunctions will be gone. That simple resetting procedure. Good luck!
About body low to the ground probably there are some problem with airmatic.
Car on in park position. Turn right and left and after push brake. Also after that try to turn off engine pull the key from ignition and in minute or so start engine again.
