2002 Mercedes C320 Rough Idle while in gear.
Old Oct 23, 2013 | 10:48 PM
fredc888's Avatar
2002 Mercedes C320
Hi folks,
I have a 2002 Mercedes C320 with 56k miles on it.
Recently, the car started to idle rough when in gear (but stopped).
It idles fine and smooth when in park/neutral.
I changed the spark plugs, the air filter, the fuel filter, and that did not really help. I checked the vac lines and they don't seem to have any wear/leaks...
I hooked up an OBD II scan tool and didn't get any fault codes.
The reading on my tool was (when the car was in gear idling):
Rev: 553-564rpm
Intake: 52-58kpa
MAF 5.4-5.5
Timing -14.5degrees
When the car was in park/neutral
Rev: 690rpm
Intake: 42kpa steady
MAF 5.0
timing: -16degrees
Any idea what might be causing the rough idle? I did some search on the forum, and looked at what others posted that might be suspect.
The things I haven't checked are
1. the motor mounts (which I think is unlikely in my case, since I would think it would be idling rough both in and out of gear if that were the case)...
2. The MAF/throttle body... The idle is silky smooth in gear, but when in gear, the idle drifts between 550-565 RPM....
Any ideas?
Old Oct 26, 2013 | 01:07 PM
transmopar's Avatar
1999 dodge ram 1500 slt
Have you tried flushing the injectors or doing a induction cleaning?
You might want to Try checking the fuel pressure as well.
