New Airbag Installed - SRS ALERT -
Old Nov 7, 2013 | 02:37 PM
im4umia's Avatar
2012 Mercedes CLS 550
I installed an AMG steering wheel to replace my base model steering wheel.
Disconnected power before proceeding.
After removing the air bag, could not get the center anchor screw loose to remove the steering wheel.
Reattached power to drive to Home Depot to purchase a torque wrench for use in removing the screw. (FYI - it worked great.)
Turned on ignition and received 'SRS Malfunction' alert. Since I didn't have an airbag attached I didn't think much of it and headed off to Home Depot.
Now I have everything in place. The steering wheel works perfectly and the airbag is installed.
However, I am still getting the SRS alert.
Am guessing that I should not have reconnected the battery without having an airbag attached and now have to go to the dealer for a computer system re-set.
Does anyone know another option? Is there a way to clear this? Or...is it just best to go to the dealer and be better safe than sorry.
Old Nov 22, 2013 | 07:41 PM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
There is nothing wrong other than a fault code when you turned on the ignition/auxillary when the airbag was removed. Find an independent shop that has a SDS and they can turn it off. Otherwise the dealer will clear the fault code and charge your 1 hr of labor time.
