2007 S550 P0128 code
Old Jan 15, 2014 | 07:15 PM
Tcompound's Avatar
2007 S550 4Matic
Since the weather has been below freezing here my vehicle temp gauge usually rides around 50-60 when its usually around 80+. The heat doesn't work as well either. I just purchased the car 3 months ago. Some one told me to flush the coolant because there might be water and its freezing up when the outside temp is too cold. Also when its 35-40 outside the car runs at normal temp and the heat works great.
Any suggestions?
Old Jan 15, 2014 | 09:16 PM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
Replace the thermostat.
It's a variable thermostat which allows the engine to run hotter when the ambient temp is lower. Sounds like it's still doing that correctly but it's just opening too early across the whole range.
