View Poll Results: How often do you change your oil?
+15,000 or 12 months
11.11%
10,000 max or 6 months
88.89%
Voters: 9. You may not vote on this poll
M271 Engine Timing Chains???
Old Jan 27, 2014 | 04:19 AM
mercedes4ever's Avatar
2004.7 C180 Kompressor, BMW X5, Chevrolet Camaro LT, Mercedes S, Cesna 152.
Question M271 Engine Timing Chains???
Hi,
I'm thinking this has been done before, I'm new, so cut me some slack
My Mercedes Indie Tech [used to be an tech instructor with M.B. for 20+ years] told me, in his opinion, changing the engine oil / filter every +15,000kms as per Assyst... is way too long even with Merc Synthetic Oils [Mobil 1]??
On M271 engines the only failures re timing chains he has seen, are cars that have gone 15,000kms + 1 year or more between oil changes. Everything done @ 10,000kms max has been fine ...NO STRETCHY DE CHAIN
He has a substancial M.B. Indie Shop & is well respected by M.B.
Sludge forming is the culprit in his opinion, which is negated by more frequent oil changes ie 10k max or every 6 months, whichever comes first.
On a side note: he does not use or recommend oil additives, but has torn down 6 M271's that had been using Liqui Moly Ceratec & commented that they where the cleanest engines he has ever seen...they all had in excess of 350,000kms one was over 490,000!!!
Your thoughts people??
Old Jan 27, 2014 | 05:12 AM
mohd.awaly's Avatar
mazda mx5
hmmm sludge forming from old oil is a problem in all cars old and new , sludge will make it very hard for oil to reach many parts of the engine ... in recent engines , variable valve timing solenoids ( vanos as most call it ) gets stuck and will not operate properly when sludge form inside of it . belt tensioners which are a comon problem in these engines might get stuck also and the chain will get loose and in this case the chain might jump a tooth or 2 or it might even break ...
an oil and filter change doesnt cost alot .. i recommend changing the oil and filter every 5000-7000 km !! and always use oil manufactured by known companies .. liqui molly has great oil !! however i am a ( Wurth ) fan , i owned a bmw 540 1998 for several years and used that oil , the old oil always had the same color of the new oil !!
Old Apr 10, 2014 | 06:39 PM
Hybrid42's Avatar
2012 E250 Avantegarde Coupe
Great info. Thanks guys
Old Aug 3, 2014 | 04:28 AM
tantinjan's Avatar
clk200k 2005
Hi i am using Shell ultra 5w-40 in my m271 engine. 117000 KM on the clock.DO maintenance my self she still run like a dream.
