Please Help on P0341 Camshaft position sensor signal malfunction
The only code P0341 is indelible, cant be erased even in official Mercedes Garage, before putting the ignition on the code still there.
Would like to discard the Hall transmitter sensor because I think thats not the problem.
I used a multimeter with these measurements:
The conector disconnected from sensor have 3 pins:
1 (-) 0 V. 17 Ohm
2 (Signal) 11,3 V. 0 Ohm
3 (+) 11,7 V. 920 Ohm
Is this measurements right?
What sould I do?
Any info will be thankful
