OBD2 Mode 6 definitions? Readiness Monitors? P0171 ?
Had a bad cat, replaced it.
Then intermittently getting P0171 ie lean condition and sometimes it clears itself.
Could not get the car to "Ready" status
Using "Torque" on my android I'm able to see the Mode 6 diagnostic data.
Here's what I'm getting:
Test report: What is TID:$01 CID:$01 on Mercedes Benz?
What is it telling me?
I hear it varies by mfg and vehicle.
TID:$01 CID:$01
- Rich to Lean sensor threshold voltage(constant)
Max: 64
Test result value: 115
FAIL
TID:$02 CID:$01
- Lean to Rich sensor threshold voltage(constant)
Max: 64
Test result value: 19
PASS
TID:$02 CID:$02
Max: 64
Test result value: 12
PASS
TID:$03 CID:$01
- Low sensor Voltage for switch time calculation
Min: 45,875
Test result value: 46,053
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
- Rich to Lean sensor switch time(calculated)
Max: 21,568
Test result value: 21,557
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
- Lean to Rich sensor switch time(calculated)
Max: 25,000
Test result value: 283
PASS
TID:$06 CID:$02
Max: 25,000
Test result value: 203
PASS
TID:$08 CID:$01
- Maximum sensor Voltage for test cycle(calculated)
Min: 154
Test result value: 255
PASS
TID:$09 CID:$01
- Time between sensor transitions(calculated)
Max: 1,200
Test result value: 260
PASS
TID:$0a CID:$01
- Sensor period(calculated)
Max: 32,943 Min: 32,593
Test result value: 32,919
PASS
TID:$0a CID:$02
Max: 49,151 Min: 16,384
Test result value: 47,639
PASS
TID:$01 CID:$01
Max: 64
FAIL
TID:$02 CID:$01
Max: 64
PASS
TID:$02 CID:$02
Max: 64
PASS
TID:$03 CID:$01
Min: 45,875
PASS
TID:$05 CID:$02
Max: 21,568
PASS
TID:$05 CID:$03
Max: 30,368
PASS
TID:$06 CID:$01
Max: 25,000
PASS
TID:$06 CID:$02
Max: 25,000
PASS
