Rear turn signal not working on factory installed LED
I originally assumed that the LED strip has failed and so I purchased a new used lamp from the wreckers. After installation I still had the same issue. Trying to eliminate the potential coincidence of both lamps having a failed strip, I replaced it for another again. Still same issue, so it looks like the actual lamp assembly is not the problem here.
There is electricity coming in to the light assembly. All other turn signals and lights are working fine.
So, is there a turn signal relay or module I should be looking at as my next step? If so where are they located and how can they be tested? Any other suggestions?
Thank you in advance.
