2004 cl window auto close and open problem
okay, my drivers side window doesn't lower slightly when i open the door and doesn't raise when i close the door. did the reset and no go. if i raise the driver's window all the way while in the car with it running and let off button immediately the window will lower about 3 inches. well i tried the passenger window and it wont auto raise, or lower when i open , or close the door either. tried the reset on both doors. no luck. is there a common module that works both windows? strange that both windows are the same.
is reset raise window all the way up, hold button for 3-5 seconds, lower window all the way and hold button for 3-5 seconds, raise window all the way and hold button for 3-5 seconds. that's what i did on both windows with no luck.
any help would be appreciated. btw, door speakers work on both doors and every other function on doors work including soft close
mazda mx5
Whats your car ??! 203 ? If it is then i doubt it has auto raise and lower features for both windows ... u can feel it from the buttons . Auto button clicks twice whn you push it all the way .
it's a 2004 cl600 and i know the drivers has the raise and lower feature. it has worked for years. i also believe i had it on the passenger side, but i can't be sure. any help?
CL55, S550, 450SL
bingo! disconnected the battery and did a reset and as of now everything is back to normal.
thanks
thanks
