ML320 doesn't start
ML320 doesn't start
hello
i have a ML 320 (2007)
when is start the enging stalls immediately.
when i disconnect the MERCEDES-BENZ A 005 153 50 28 Sensor, boost pressure the engine start but has no power.
i replaced the sensor but the problem stays.
anybody has an idea ?
Most likely you have a bad battery. Do not try to "jump" start the car unless you know the correct procedure. Major thing to avoid, have your key OUT of the ignition when hooking up the battery for a jump, and put the key back in AFTER the cars are connected.
Here in the US it is called aGroup 49 batery (from memory), although some replacement batteries will be not as tall as the OE battery, requiring adding a non-conductive pad under the battery hold down bar.
Keep the beat !
Keep the beat !
