c280 questions
Old Dec 29, 2003 | 01:31 PM
raskens's Avatar
1994 c280
c280 questions
i am working on some oil leaks on my 94 C280. When i was replacing the valve cover gasket i noticed that all torx head bolts that holds down the camshafts are filled with something that look and feels like grease. I was wondering if anybody knows if this is done at the factory to prevent dirt buildup or could it be something else. My car only has 55,000 miles so i don't think it is regular buildup
Old Dec 29, 2003 | 05:02 PM
sph17's Avatar
02 W163, 84 W123, 03 E39, 98 E39
Re: c280 questions
Originally posted by raskens
i am working on some oil leaks on my 94 C280. When i was replacing the valve cover gasket ...
Your profile lists you as a 1994 C280 which has the I-6. The C-280 V-6 which started production in 1998, I read, has oil leak problems of it's own.
<sph17>
Old Dec 31, 2003 | 06:55 AM
Batman's Avatar
95 M3, 98 C280, 97 E320 (sold)
The 98 C280 has oil leak problems? Where? Is it fixable? Do you have a link with more info?
Old Dec 31, 2003 | 11:18 AM
sph17's Avatar
V-6 Oil leak problems
Check the W202 forum and look for questions about "Im going to buy..." Or "Reliability of...." as headers. When the forum went down in the Fall, a number of months of content was lost, so you can only go so far back before there is a big blank space in time.
My remembrance is that early 98 had crankshaft seal problems. You can also check www.culub202.com also.
https://mbworld.org/forums/showthrea...threadid=53059
