Power steering fluid, differential oil
w203 mercedes c class, 2010 toyota Corolla Altis, 2006 toyota corolla, 1996 Mitsubishi Mini pajero
i have a Mercedes w203 c180 2002 model done 87000miles since new
it steering rack was replaced and it was filled with Mobil 1 synthetic ATF, its been driven 1000km since then no issues, it feels right and no noise but can ATF cause problems? should it be replaced with Central Hydraulic fluid? please also explain the procedure slightly, its drained by a drain bolt at the bottom after removing from underrshield?
also its rear differential oil has not been changed but level is correct is there a need to change it?
some of the coolant was once lost due to removing a hose pipe, currently it contains majority glacentine coolant and some water, is it harmful?
keep in mind car is ver yearly driven and has a annual milage of 1000miles a year max
