Engine running to cool
So any ideas , has this happened to anyone else that found the problem. Sure normally low temp wouldn't seem to be an issue but since I've not noticed this in the past I have to think something is wrong.
Should I be concerned? Thanks
No doubt about it. This is a common problem with the CDIs and those of
us who have these cars have either replaced it already or soon will!
Not expensive, as I bought the complete housing with a new thermostat
in it and a temperature sender and gasket for less than $60.
Yes sir, you are spot on about the leaking fuel tank issue.
Have you found out that our CDIs are being covered under this new warranty?
Mine is getting rather bad as it has now 182K miles and is just getting worse all the time.
But the rest of the car is fine and getting stronger all the time as the miles build!
Has anyone found out if the CDIs are actually covered?
If so, I will need to see my friendly dealer and get mine repaired.
Thanks and regards,
Derrel H Green
Driving 'old smelly' sometimes 300 miles a night.
On the fuel leak, I'm thinking they are not going to be doing anything to help us since no one has died from it. I'll have to see if there is a threat with DIY directions to follow. Probably no hard just we shouldn't have to pay to fix this sort of problem IMHO.
See: https://mbworld.org/forums/w211-amg-81/ and although we do not have E-55s, we DO HAVE W-211s and they are all covered I believe.
Read the first one at the top, a 'sticky': ! ! ! ATTENTION ! ! ! !
FUEL LEAK ISSUE . . .
Now your dealer may say your CDI is not covered, but I think it is!
Then call into MBZ as these E-55 owners are doing and take it from there.
Remember, the squeaky wheel always gets the grease.
Regards your bad thermostat, the part is available for less than $60
I think, but it has been almost three years since I did mine.
Easy to do, and it will keep yours at the recommended 92C.
Mine would run as low as 40C cruising on the freeway in January,
2012 shortly after I bought it 12-17-2011.
Stupid dealer where the original owner had it serviced 22 times
in seven years failed to see that problem!
Don't be afraid to landline me at 951 834-0433
I don't bite!
Regards,
Derrel H Green
