Help, loud passenger noise 09 c300 AWD
Old Nov 21, 2014 | 04:01 PM
Synolimit's Avatar
09 C300 Sport
wifes 09 c300 AWD started making a noise in the front passenger area. the noise is now loud! and gets louder as you go faster. its a constant noise but not a grind or metal sound. i was 100% sure it was a wheel bearing as again its not a grind and its something spinning 360 degrees with no flat spots like a warped rotor would have. also at the rate its spinning its very fast! a wheel or rotor would spin slower since it has a larger diameter. this noise spins fast like a bearing or axle or something.
yesterday i pulled everything off and the bearing did feel "tight." i popped the old one out and it looked fine. well i bought a new one from the dealer and installed and it didnt feel any different in my hands. i put everything back together and went for a drive and everything is 100% the same!!
now im thinking a bearing in the front transfer case maybe?? i really dont know at this point and it sucks!! also after i installed everything i now have no ABS, traction control, and a check brake pad wear light. i did have the radio on when working on it so unplugging everything with the power on im sure it thinks all that stuff is broken. so i need to do a full master reset or something as its all plugged back in and working ok.
anyone???
Old Nov 24, 2014 | 01:32 PM
Synolimit's Avatar
09 C300 Sport
Hello?
