W203 C32 engine noise??
I have a what sounds like a grinding noise coming from the engine when the stops (thats when its quiet enought to hear it i guess). It does not make the noise when at idle or at any other rpm when stationary so it makes it hard to pin point. The easiest time to hear it is when im in an under ground car park when there is no throttle input and it lasts for about 5 seconds thrn stops. If i Tap the gas pedal it starts again for about 5 seconds then stops. If i just release the brake and roll foward no noise also no noise if i gently accel away but again when no gas pedal the noise comes back.
