need help, offering paypal in return
the screw broken in half is shown inside the red circle
Using a 1/8 sharp drill bit position on the punch mark and slowly drill in line with the stud through the center punch mark. Slowly as to build up some heat in the stud, drill in 3/8 to 5/8 inch into the stud. Now with a 3/16 inch drill bit do the same into the 1/8 hole, after doing this insert an "Easy Out" into the 3/16 hole using a hammer to seat the easy out, slowly reverse the stud out while there is still some heat from the drilling.
Good Luck it will take patience and accuracy and skill to complete the operation, if possible try a larger drill bit but not large enough to get into the thread area. Use the other hole for maximum drill size then reduce to one smaller. With the heat created the stud may back out, steel and aluminum like to stick to each other, anti seize would be a good investment on the rebolting procedure, it will never stick again.
Good Luck I realize space is at a premium and will be the biggest obstacle.
I usually prefer tapping to a larger bolt (provided I have enough material to work with) over a heli-coil as helicoils have a tendency to come out with the bolt next time it's removed, and they often bring the aluminum with them.
If you DO resort to a helicoil, make sure you use plenty of corrision resistant lubricate, such as molylube or some such.
If it broke trying to remove it initially and didn't over tighten it causing it to snap it probably won't come out and is seized. You can try spraying PB Blaster a few times and let it sit prior to removing.
If you must drill it all the way out use a good bolt as reference for how deep you need to go.
Good luck!
