2006 cls55 no blade key and dead battery
Old Mar 21, 2015 | 01:34 AM
projectnsx's Avatar
2006 CLS55 AMG
Haven't driven my car in 6 months or so and to my suprise my battery is dead. I do not have the blade key. What's the best way to get into my car other then calling AAA? Thanks for any help in advance.
Old Mar 23, 2015 | 04:10 AM
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
I don't know how accessible everything is on your car but I would try and jack up the car, remove the under body/engine cover and see if you can connect a battery charger to either your alternator or starter battery connections. After you charge it up for a bit you should be able to unlock your door.
Old Mar 23, 2015 | 12:27 PM
projectnsx's Avatar
2006 CLS55 AMG
The only problem is that my car is lowered and where it's parked it will be next to impossible to get a jack underneath. I've slim jim other cars I just thought there might be a trick to this one.
Old Mar 23, 2015 | 02:47 PM
krazzdav's Avatar
There's nothing to "slim jim" on Mercedes. There is only a cable that goes from the interior handle to the door lock actuator and is all on the interior side of the door until right at the lock which has a cover over the cable anyhow.
Your only other hope is to wedge the door open and fish for the interior handle then to open it from inside.
Old Mar 23, 2015 | 03:00 PM
krazzdav's Avatar
Also the door lock button you can't get to....on a different model MB there's a plastic cover that blocks this keeping water off the lock and would think it's similar for all models.
If you do a search for a door lock actuator for your car you will see how it's made with the cables, rod and wires attached.
Old Mar 23, 2015 | 08:58 PM
projectnsx's Avatar
2006 CLS55 AMG
I guess I'm better off calling AAA and having them handle it. I originally thought it was my remote battery but after getting a new one still nothing. Thanks for all the help.
Old Mar 23, 2015 | 11:22 PM
biker349's Avatar
cl600
let us know how you solve this.
