Are these fault codes a sign of a bigger issue?
Any thoughts? I posted this in the GL forum as well, but figured this would be a better place.
Hi,
I have almost the same error codes in my Gl350.
Did you tried to clear these codes? I am wondering if I should clear it and re-check after some time if are still detected by my vehicle.
best regards
PJ
Battery could be very low.
I have opportunity to erase these codes by myself, but I am not sure if I should clear it or leave it for further verification. Despite these codes everything is working without problems.
anyone having a bad battery or battery disconnect , take a screen if you want (99% useless), always erase your faults first; Then run the engine, drive a mile, and run diagnostics
tons of false faults will appear with low batteries. having bad batteries is very toxic for your modules
