airmatic pump running permanently over 20km/h and stops below this speed
Old May 19, 2015 | 05:30 PM
ariquelme's Avatar
ML280CDI
Hello,
I had several problems with the airmatic of my W164 (ML280CDI).
Now I have checked that over 20km/h (12,5mph) aprox the airmatic pump starts running and keeps running until vehicle speed drops below 20 km/h exctly.
Is this normal ?
Old Jun 18, 2015 | 09:50 AM
ariquelme's Avatar
ML280CDI
Hi again....
After broken the plastic case attached to the compressor (where the air line comes out to the valve block), and 2 air struts, I decided to place a led parallel to the compressor power connector, and checked exactly that as soon as the car reaches 44 km/h, the compressor starts running permanently, and only stops when the speed drops below 23 to 24 km/h, so I guess this was the reason of so many failures.
Now the point is what is making the compressor start running every time the car goes over 44 km/h ?
I was thinking about the speed sensors, but the electronic speed control works fine, the ESP works fine, so I don't think is related with that.
Any help is much appreciated.
Tks,
Antonio
Old Sep 29, 2015 | 07:52 AM
nuqi's Avatar
R320 2006
Hello Antonio,
How did you solve this issue because I'm facing the same one. I replaced the compressor but still the same issue.
Old Oct 1, 2015 | 06:22 AM
mike278's Avatar
2011 GL450
I believe the system is designed to run the compressor when the vehicle is moving over 20km/h. Pretty sure I read that in the system description somewhere. This masks the noise and keeps the central reservoir pressurized. Are you experiencing any faults currently?
Old Oct 1, 2015 | 09:29 AM
mike278's Avatar
2011 GL450
I need to revise and extend my remarks. The compressor runs IF the central reservoir detects insufficient pressure, and the speeds for compressor operation are 40km/h under acceleration and 20km/h under braking. Seems like there may be a leak somewhere.
Old Feb 15, 2023 | 03:48 PM
Tiit,w164's Avatar
ML W164
Hello,
I have exact the same problem with ML W164, the compressor starts at 40km/h and cuts off after slowing down to 20km/h
Also keeps running when the car level is raised to higher positions(offroad pack). No leak detected anywhere. Compressor pumps around 16 bar. Can the problem be airmatic ecu under the driver seat?
Any ideas will be helpful!
