ML320 2009 BlueTec coolant leak and short circuit
Hi All,
Just registered so greetings to everyone. I was driving last night and everything was normal as always, but at one point the car lost it's power and did not accelerate well. Also I've got a message with thermometer (assuming overheating). So I've stopped and shut off the engine. Started the engine and got check engine light. Then I had to drive another ~50 km and sometimes can barely accelerate to 50 km/hour. I was watching temperature and it was between 80 C and 90-95 C. Also I've noticed that after accelerating to over 60 km/hour power comes back (not to the full extent, but enough so I can drive). So this morning I checked the coolant level and it was below, so I added about 0.5 - 0.7 liters of coolant. I've also noticed fluid (assuming it's coolant) on top of fuel filer! Also I've remembered that yesterday while driving I was getting condensation on the windshield. I've connected a computer and got tons of errors. Below are some of them: 129700 The diesel particulate filter is defective. 100D00 The lower limit value of component B2/6 (Left hot film mass air flow sensor) has been reached. 100E00 The lower limit value of component B2/7 (Right hot film mass air flow sensor) has been reached. 101500 The lower limit value of component B2/6 (Left hot film mass air flow sensor) has been reached. 101600 The lower limit value of component B2/7 (Right hot film mass air flow sensor) has been reached. 105700 Component Y27/9 (Left EGR positioner) has Short circuit to ground. 10B900 Component B16/15 (Temperature sensor upstream of SCR catalytic converter) has a plausibility error. 10C200 The control line to component M4/7 (Engine and AC electric suction fan with integrated control) has Short circuit to ground. 113D00 The heater for component G3/2 (Oxygen sensor upstream of catalytic converter) has a short circuit to positive. 11F100 The lower limit value of component B2/6b1 (Left intake air temperature sensor) was dropped below/not reached. This leads me to believe there's some kind of coolant leak that got all these sensors shorted. Also I've remembered that while I was driving yesterday my iPhone was arbitrarily disconnecting and reconnecting over Bluetooth (which never happened before). Any advice where I should start looking or anyone has experienced the same or similar issue? Thanks a lot in advance! P.S. I've got full STARS report if that's of any help. |
Check the fuse box on the passenger side under the hood. I believe it's fuse 20, but I really can't remember exactly. I haven't had my coffee yet, but I believe the m55 intake flap actuator goes bad and blows that fuse. If you have the proper scanner you can run the self-test on the motor. Hope this helps.
Thanks a lot Mike for the suggestion.
Yes, it turned out to be couple of fuses and the M55 motor that failed. Before that I had to do a whole intake manifold gasket replacement (as well oil cooler seals replacement as well, just in case). I think there was coolant leak there as I could see traces and once I took intake manifolds off, I could see whoever did oil cooler seals replacement, used old gaskets and some kind of black car sealant substance (what a mess!), so I got all the new intake manifold gaskets (as well as turbo and other gaskets and o-rings), cleaned all the mess and did the install. At that time I did not check fuses and M55 motor seemed to be working. Maybe I messed it up when installed but in any case when I got to the motor it was fried and one of the levers from the link bars was broken. So I've done the resistor trick, disconnected the motor and fixated the link bars in flap-open position. That worked great. However I've got bot B96/1 and B96/2 sensor errors reported and check engine light on because of these. I guess the sensors are OK, it's just the computer thinks that the sensors do not register different positions (flap-closed positions I think in particular) in case the signal from the computer goes to the motor to change the position and sensors do not register that although computer thinks motor did that (of course there's a resistor that tricks the computer). Any way to trick the computer to think that sensors work as well or maybe disconnect these altogether? Thanks a lot! |
What was the final verdict on the noise?
Continuing AC issues with 2016 MB
My AC wasn't working properly shortly after purchase. Then 5 months later started blowing uncooked air out of driver's vents again, this time with less pressure and started smelling bad. Said a hose was kinked maybe from closing vents too hard... NOT! I live in central California where you dont think of even closing the AC vents between May through Oct! They fixed the smell and AC worked well for 30 hours....Taking it in for the 3rd time ;(
Noticed yesterday before appt. that spontaneously for a short time it sent out cool air through driver's vent. Strange. Can it be an electrical problem? Do I have a lemon? |
Hi dadd,
I have the same diesel fuel tank leak problem on my 1995 E300D. I plan to remove the tank tomorrow and check if it can come from behind but it appears for me to sweat through the welding points. What was the cause and solution in your case? |
Pre-safe and all others with loss of power on w212 e63s AMG
I have started getting the full.sensor failures accompanied occasionally with loss of power.
Where is the CAN Wiring loom In mine ? TYIA, Mart. |
sorry post in wrong thread
How do i clear the codes?
Same boat
https://cimg5.ibsrv.net/gimg/www.mbw...133bd6b7b6.jpgBad luck for me California 276motor fail. Kn filter installation.
Originally Posted by Flipbound18
(Post 7224812)
1999 CLK 320
1 Attachment(s)
Hi all,
I have been reading this forum for a while, contacted Klaus (my best regards to him) who was very kind and helpful, but I am still not able to locate the fault in my soft top opening (or the lack of it). In words: the roof starts to open correctly, glass folds back correctly, back compartment opens, then the back window unfolds towards the compartment, once the top is stretched and about to enter the compartment it jerks and stops. I checked the wires for the back bow lock and the other lock - both working fine (some damage, but not broken) - fixed. Any suggestions based on the video? Reagards, M |
Originally Posted by newoldclk208
(Post 7279920)
Hi all,
G3/2 Error
Originally Posted by dmitry_sorokin
(Post 6544687)
Hi All,
(Post 6544687)
I was driving last night and everything was normal as always, but at one point the car lost it's power and did not accelerate well. Also I've got a message with thermometer (assuming overheating). So I've stopped and shut off the engine. Started the engine and got check engine light. Then I had to drive another ~50 km and sometimes can barely accelerate to 50 km/hour. I was watching temperature and it was between 80 C and 90-95 C. Also I've noticed that after accelerating to over 60 km/hour power comes back (not to the full extent, but enough so I can drive). So this morning I checked the coolant level and it was below, so I added about 0.5 - 0.7 liters of coolant. I've also noticed fluid (assuming it's coolant) on top of fuel filer! Also I've remembered that yesterday while driving I was getting condensation on the windshield. I've connected a computer and got tons of errors. Below are some of them: 129700 The diesel particulate filter is defective. 100D00 The lower limit value of component B2/6 (Left hot film mass air flow sensor) has been reached. 100E00 The lower limit value of component B2/7 (Right hot film mass air flow sensor) has been reached. 101500 The lower limit value of component B2/6 (Left hot film mass air flow sensor) has been reached. 101600 The lower limit value of component B2/7 (Right hot film mass air flow sensor) has been reached. 105700 Component Y27/9 (Left EGR positioner) has Short circuit to ground. 10B900 Component B16/15 (Temperature sensor upstream of SCR catalytic converter) has a plausibility error. 10C200 The control line to component M4/7 (Engine and AC electric suction fan with integrated control) has Short circuit to ground. 113D00 The heater for component G3/2 (Oxygen sensor upstream of catalytic converter) has a short circuit to positive. 11F100 The lower limit value of component B2/6b1 (Left intake air temperature sensor) was dropped below/not reached. This leads me to believe there's some kind of coolant leak that got all these sensors shorted. Also I've remembered that while I was driving yesterday my iPhone was arbitrarily disconnecting and reconnecting over Bluetooth (which never happened before). Any advice where I should start looking or anyone has experienced the same or similar issue? Thanks a lot in advance! P.S. I've got full STARS report if that's of any help. G3 /2 error is the oxygen sensor upstream of catalictic converter and in your case like mine it might be below the air filter box, where you will be working on the turbo anyway. Get the Bosch O2 sensor and some antisieze compound and change it at the same time as the turbo problem. |
Thanks. Rudeney. It turns out to be the issue of camshaft Adjuster. MB dealer charge $2900 to fix the issue. plus $220 diagose cost and TAX, it costs me $3100 in California.
W211 shut off motor problem
Hi Dmitry, i am having the same issu with my w211 V6 320 CDI, i have replaced the shut off motor cost $490, but problem came back a week later. I have read about the resistor trick but have a question on that. What type of resistor do u have to use? Is it specific? Thanks.
(Post 6559980)
https://cimg3.ibsrv.net/gimg/www.mbw...7c2633b50.jpeg I have a 2008 Mercedes Benz gl450 & this is the cable from the glove box Mercedes there is no part number for it |
Coolant Breather Pipe Connector
Its part number: 003 997 0689
https://cimg1.ibsrv.net/gimg/www.mbw...647150e3a.jpeg |
Hi,
On the other hand, please look at your battery as I had lots of error messages like your oxygen sensor message ONLY because the Varta battery failed after ten (!), yes ten years. The confuser gets confused a lot due to low voltage and the diagnostics go berserk with error messages plus you get into "limp" mode. Once I changed the battery my MB2 diagnostic became silent. |
Wrong thread?!?
Hello people,
I got the "fuel smell both inside and out" made an appointment with MBSD USA. Great experience. Took in the car on Thursday - they had no loaner for me but no worries, they took care of that through enterprise. Diagnostic and the result was a new tank completely covered. Got it back today and paid nada. Wash and vacuum to boot! Thank you MB and MBSD USA for standing behind this issue. Rob |
All the stuff is there to conform to the Emissions Level laws. Defeating or deactivating them and then driving may be illegal. There is a $10,000 penalty if you get checked during registration or emissions tested. It IS good you figured out how to operate in 'the limp home' mode until you can get it properly repaired.
FYI You might write a "Letter to the File" detailing the entire situation to document the attempted repair and work-around. Many states have a provision that allows an exemption from emissions requirements if you can show you have already spent so many dollars on attempted repairs. Such a letter may keep you 'legal.' and avoid a big penalty. Remember our Criminal Justice system goes after (prosecutes) we 'small guys' because we cannot afford a costly legal defense while the really 'bad' guys get away. |
I seriously doubt that a cleaner will do anything. The evaporative emissions system sucks fumes out of the system to protect mother earth, nothing more. The code I had is telling me/you that the system is unable to pull a vacuum, insinuating a leak somewhere in the system. That's why the first excuse they always give is to check the gas cap. You shouldn't have any symptoms at all of the truck running bad, it's just a nuisance.
All that being said, in less than 3 years, I replaced wheel bearings, brake rotors, rear shock mount, auxiliary battery (start stop) failed, seat stitching was coming undone. I was fed up, and when the dealer told me I needed to pay more to get better quality, I told him his logic was flawed and promptly sold the GLK private party. Good luck with it, but honestly I think it's nothing more than a nuisance. |
Wrong thread
Does anyone have a writeup on where to place the resistor that is mentioned in another thread? Is it easily accessible when I open the hood? Also, does anyone know what fuse blows? I want to check the fuse - as I am having the same exact problem as described in this thread.
