2003 E500 Sedan
Old Oct 27, 2015 | 02:24 PM
bthe1wilson's Avatar
2003 E500 Sedan
2003 E500 Sedan
Is there a shorter serpentine belt that I can get for my 2003 E500 Sedan to bypass the AC?
Old Nov 2, 2015 | 07:18 AM
mike278's Avatar
2011 GL450
Easiest way to determine a non-standard belt length is to remove the belt and use a piece of twine or small rope to route around the pulleys (with the tensioner pin holding it in the service position). Remove it and measure. Convert to centimeters and talk to a knowledgeable parts person (hard to find) or go online and find one the right length and with the same width with the same number of ribs as the original.
Old Sep 9, 2016 | 01:38 PM
Azeem's Avatar
W211 E270 cdi 2004
Can you send me measurement of driving side mat? The other 3 should fit fine.
Old Sep 16, 2016 | 12:04 AM
Holmes5518's Avatar
2016 C450
There's a shorter belt that benz uses as a special tool to eliminate the ac compressor during diagnosis. You should be able to buy it at the parts department.
