Breaklight switch failure but break lights work?
Old Nov 19, 2015 | 07:07 AM
Joe Waldrop's Avatar
02 clk430 convertible 97 sl500
I'm getting a break light switch failure in my w208 but my break lights work, also have the abs/esp/bas lights on the dash. I was messing with the switch and I noticed a wire tapped into one of the wires connected to the switch I traced it back to the right break light. Not sure y the previous owner did that. But will the break lights work with a bad break light switch?
Old Dec 4, 2015 | 07:28 AM
Ausmbtech's Avatar
190D 2.5 (x2), 190E 2.6, W202 C240,W202 C43 (C55), W210 E55, W212 E250CDI
The brake light switch has 2 physical contacts within it. 1 set operates the brake lights and the second tells the ABS that the brakes are applied. the ABS/ESP control units monitors both contacts, if they don't both do the same thing at the same time it logs a fault. That's how it knows there is something wrong.
