S500
Old Dec 21, 2015 | 10:35 AM
Ensayn_3's Avatar
1997 S500
S500
Hello Benzo Family, i hIve a problem and I hope someone can help me with this. I have a 1997 S500 that won't start unless I spray it. Even then it cuts off when the spray runs out. Changed fuel pump, filter, cleaned the injectors which was good by the way as I tested each one. I was told it was the fuel pump and thats why the fuel gauge stop working. Still not working after the new one was put in. I've checked the pressure in the fuel rail and have more than enough.... Help plz
Old Dec 21, 2015 | 07:52 PM
mike278's Avatar
2011 GL450
sounds like you need to get a cheap noid light to see if the injectors are firing
Old Dec 21, 2015 | 08:08 PM
Ensayn_3's Avatar
1997 S500
I did and they are working like they should
