2012 C250 ESP Fault with a P2118 Throttle Actuator fault code
One other resent issue is that intermittently when passing the vehicle feels as though it has hit something! Like the front axle just dropped in a hole. And the car momentarily loses power. No faults are illuminated. I assumed it was the turbo over-boost protection but I’m not sure.
Both problems started within a week of one another thus making me think they are related.
I finally had a hard failure and the check engine light set. I had the code read with an OBD-II reader and the code that was stored in NVM was P2118, a throttle actuator fault. Not the costly fault code I wanted to see.
My question is, Could a battery that is starting to degrade be responsible? I did have my battery tested and it passed. The battery is the factory original so that dates it to 2011 so a battery life of close to 5 years. The concerning part about the battery other than the age is that the only comment on the diagnostic print out is that it needed to be fully charged. I had just been driving the vehicle for 30-45 minutes so if anything it should have appeared to be over charged, or a “hot battery”. The battery was not only tested under a cranking load but also under a demand load. My alternator was consistent with a good output. I have had the vehicle for 17 months and put over 70K miles on it with no problems other than routine maintenance issues.
Any insight is welcome. Thanks in advance!
