Starting issues
Old Apr 26, 2016 | 01:13 PM
Dayne6399's Avatar
R 350
Starting issues
I need help!
I've got a 2010 R 350, I started having
Problems with starting the vehicle, when I turn
The key I get nothing not even a sound,
This only happens when the vehicle has been driven
Or it's warm outside, after the first start of the day
Have to wait hours for it to start again
Dealer said I needed a new key, got that and still same
Problems, now it's next we'll try this, anybody have this
Issue and a fix without having to try this and that?
Help would be much appreciated
Old Apr 26, 2016 | 10:04 PM
GLENN S.'s Avatar
mb, saab, acura, dodge
No starter sound or/and no lights on dash? If it's just the starter, try starting in neutral.
Old Apr 26, 2016 | 10:09 PM
Dayne6399's Avatar
R 350
Thanks Glenn I'll give it a try and let you know
Old Apr 26, 2016 | 10:14 PM
GLENN S.'s Avatar
Could also be a bad starter?
Old Apr 26, 2016 | 10:16 PM
Dayne6399's Avatar
R 350
My shifter is on the column, up for reverse, down for drive and push
Button for park, it won't let me put into
Neutral
Old Apr 26, 2016 | 10:20 PM
Dayne6399's Avatar
R 350
Wouldn't I be getting some sort of sound if it were starter?
It starts first thing in the morning with no issues, like went to
Work 6:30 am started fine worked 12 hours went out started
Fine, went out now hour after getting home won't start but will
Again in morning
Old Apr 27, 2016 | 08:46 PM
GLENN S.'s Avatar
When you get home, open the hood, then go out an hour later & see if it starts.
Old Apr 27, 2016 | 08:55 PM
Dayne6399's Avatar
R 350
I will do that, someone else mentioned
A starter relay, I'm going to try that too
And another mentioned checking the battery
Hopefully by the process of elimination!
Just didn't know where to start and no real
Help from dealership, thanks again
Old Apr 27, 2016 | 09:06 PM
GLENN S.'s Avatar
When you find the starter relay, match up the no. with another relay & swap them
