300 D run on
230TE 280TE 300TE
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
W124 300D Take out the ignition key and the engine runs on as if nothings happend.
What could cause this?
If anyone has any ideas it would be much appreciated.
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
97 e420, 81 240d, 87 190-16v, Dodge Cummins Diesel
there is a fuel cutoff solenoid that shut the motor down. The car can run without electrical power so I assume is takes a power source to shut the fuel off. There is usually a manual level to cut fuel as well. Dig around.
02 W163, 84 W123, 03 E39, 98 E39
Re: It may be as simple as a
Originally posted by Steve Clark
vacuum leak.
vacuum leak.
With the W-123 the most frequent place for a vacuum leak is by the firewall on the driver's side. This is where there is a valve with a nuber of vacuum hoses comming into it, with one going out, into the fire wall. Thsi is also right near the oil filter housing, and changing the oil filter would often dis-lodge the vacuum hoses. I don't know if your engine arrangement is similar.
Turbo Diesel
My 124Diesel did the same thing.
You blew the vacuum pump. And possibly the a belt or two, it cost me aruond $500 for all the parts I needed, and about 4 hours of my own hard damn labor.
230TE 280TE 300TE
thanks a lot guys sorry i diden't get back to this thread had major problems with computer as well as the vacum pipe on the bulkhead all sorted now much appreciated i'm obviousley not destin to save this car from the scrap heap.
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
