1992 300ce-24V hesitation
( champion C11YCC-the recommended ones), leads, coil, rotor, cap and fuel filter.. the works. I have also noticed slight loss of power when accelerating in fourth gear( the car is 5 speed automatic ), while doing low revs until it shifts into 3rd gear. As soon as it shifted into 3rd gear it behaved normally
( higher revs and less load ). And it never does this when cold. Only sometimes when hot. Not always though. Hmm.?
Any clues..? Anyone experienced something similar..?
Any help or ideas much appreciated.. thanks.
How old is the O2 sensor? It might be sending bogus data to the LH control unit and messing up the mixture.
And I was also wondering about the O2 sensor myself. Hooked up an exhaust gas analyzer and all emissions were within limits. CO content was to be excact 0.27%. Given value is max 0.5%
-I believe there is a knock sensor on the intake manifold. If ignition knocking is sensed, it will retard the ignition. Perhaps you could look this up for me if you have any books covering this engine.
Anyhow, I cleaned the terminals on it( I think it was a knock sensor ), they were a bit corroded. It hasn´t done this since. Been driving for a few hours now and all´s well... For now..
Thanks.
If so, is it a small black plastic box with a three-pole plug connected to it. Located in front of the fuel distributor under the air filter Attached to the intake manifold. And is there a way of testing it ?
Because I´d like to know what sensor that is that I cleaned the terminals on. Think it´s a knock sensor..
Thanks.
