merc sprinterturbo fault
A 2001 sprinter 2.2 common rail diesel
vin no WDB9036632R169327
Now for the fault Engine going into limp mode not rev above 3000 rpm
Loads of money and parts fitted.Turbo,map sensor,turbo reg solenoid
inter cooler vac pipes checked,press pipework checked for leak
FAULT CODE set p0105 plausibility it only happens at idle speed then limp
I think the fault is the control unit cant set the turbo press at idle as the
barometric sensor is to low 600m/bar map sensor reads 1025 m/bar at idle
Now I cant find the barometric sensor ( even asked local merc dealer dont know )
Ihave looked in engine compartment behind front bumper
I hope you can help as to the location of the sensor
thank joe
