HELP!!! P2540 Code
Old Jul 1, 2017 | 09:43 AM
Billet's Avatar
2008 C63 AMG
Exclamation HELP!!! P2540 Code
I am needing help... i had a CEL that came on the other day, I scanned the car and found that it had a P2540 code I then cleared the code drove approx. 5 miles and the light came on. I was watching the fuel pressure on the scanner and it was running around 52-54psi. while driving at 70MPG.
I replaced the main fuel pump on the car (Driver Side) then drove it approx. 10 miles and the light came back on. Came up the same P2540 code. I then started watching the fuel pressure with the scanner and found that the fuel pressure was not dropping off when it shifted as it did before.
I am leaving to go to Myrtle Beach on Monday.
Can anyone help me with figuring this out???
I have attached pictures of the fuel pressure before and after replacing the fuel pump, this is from 0-90 MPH on both graphs as you can see one is choppy and the other is smoother until I let out of the throttle.
Thanks,
Matt
Attached Thumbnails HELP!!! P2540 Code-img_5176.jpg   HELP!!! P2540 Code-img_5177.jpg   HELP!!! P2540 Code-img_5184.jpg
