Lights out...
Old Nov 26, 2001 | 10:16 PM
andaya's Avatar
99 ML 430
Lightbulb Lights out...
Hi . I'm new here and it's my first thread.
I have a simple question to ask and maybe it can be easy to fix for some.
My lights that illuminates the temp gauge ( three circle below the radio)
DoesnÕt work when the head lights are on. IÕve checked the fuses and seem all ok, do I have to change the bulbs? Is this easy to do?
Please help.
Jimmy
Old Nov 27, 2001 | 12:28 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
What kind of car is this? And yes, it sounds like a simple bulb.
Old Nov 27, 2001 | 12:33 AM
awiner's Avatar
2003 CL55 AMG
I clicked on Andaya's profile... Looks like he has a ML430
Old Nov 27, 2001 | 04:27 PM
andaya's Avatar
99 ML 430
Talking Thnaks
Is there an easy way to take the panel off??
jimmy
Old Nov 27, 2001 | 10:09 PM
mbtech208's Avatar
Sure is, just take the COMAND center out with MB radio keys, then remove the two retaining screws for the wood trim and the whole thing practically falls into your lap. To get the A/C dials out, there are 2 or 4 more bolts (7mm, I think).
Old Nov 28, 2001 | 12:50 AM
andaya's Avatar
99 ML 430
ok i may sound retarted..but
command center? on the radio? I'm soo new to this
sorry
Old Nov 28, 2001 | 01:17 AM
mbtech208's Avatar
Does it have a TV screen, or just a regular radio and an empty bin right below it?
Old Nov 28, 2001 | 01:50 AM
andaya's Avatar
99 ML 430
Smile reg radio with an empty bin below it.
reg radio with an empty tray below it.
Old Nov 29, 2001 | 01:23 AM
Kar don's Avatar
Mercedes-Benz
Smile Ummm take it to the dealer, it is free for them to fix it
Thats why it is called a bumper-to-bumper warranty!
Old Nov 29, 2001 | 01:28 AM
andaya's Avatar
99 ML 430
Actually that's true,.......BUT
When it's a 1999 over 50k miles, which is over the warranty period, I wouldn't be here asking, now would I ??!!!.. DUH!!!
Old Nov 29, 2001 | 01:40 AM
mbtech208's Avatar
Okay, okay, calm down everyone before a cyber-fight breaks out and I have to separate you two. To get the wood piece off on your ML, all you have to do is unclip it. It just snaps in, no screws holding it on. Try starting from the very bottom of the wood and prying it up. Be careful you don't scuff the dash though, put a towel or rag underneath where you're prying. Once you get the wood off, unplug the switches from the backside. Then take the screws out that hold the A/C dial assembly in place. Disconnect the control cables for the dials. Then there's a trick to getting the bulb out of the backside of the dial. You can use a small pair of needle-nose pliers, but don't squeeze too hard or you'll break the bulb. OR you can find a small diameter rubber hose, and slip it over the bulb. It should pull it right out, if it's tight enough.
Old Nov 29, 2001 | 02:35 AM
andaya's Avatar
99 ML 430
Thank you thank thank you!
Thank you so much for your help.
Jimmy
Old Dec 1, 2001 | 10:08 PM
andaya's Avatar
99 ML 430
hi again...
I got to the light bulb, and it's as small as one of those christmas light bulbs.
Now would you know where I can get one of these online?
jimmy
Old Dec 2, 2001 | 03:38 AM
mbtech208's Avatar
Online? I have no idea. You should be able to get one from your dealer for less than a buck though.
