Rear SAM compatibility?
Old Jul 27, 2017 | 07:29 PM
MCFB's Avatar
Mercedes CLK 200K 2003
Hi! I have a 2008 C220 W204 that needs to replace the rear SAM. However I cant find a match. I see 4 Numbers? HW/SW/LU? What Does IT mean? And the 5DK nr. Does IT all have to match? What is the part nr? Or can i use a different part nr? I Really need help to find one I can use from eBay. Or atleast know What im looking for Its driving me crazy. Thanks alot!
Old Jul 28, 2017 | 12:52 PM
MCFB's Avatar
Originally Posted by Plutoe
If you want the correct part----post your VIN
Thanks,my VIN is WDD2040081A003854
Old Jul 28, 2017 | 04:20 PM
MCFB's Avatar
The current part number is 204 906 77 02,
the following older part numbers will also work:
204 906 11 05
900 16 03
545 86 01
Regardless of what part is used, the SAM must be flashed, therefore after install you will need DAS Xentry
Thank you so much! So you can confirm this will work? Even though its from a car with a manual transmission while I have automatic?
http://m.ebay.co.uk/itm/MERCEDES-C-C...%257Ciid%253A1
Old Jul 28, 2017 | 06:26 PM
MCFB's Avatar
All I will confirm is that the part numbers I posted will work, however regardless of which part you choose it will not fully function until the SAM is flashed to your car. That is very important for your understanding ad the lack of future whining about the part not working. That also assumes that the used crap you purchase really is without faults!
Thanks. Yeah I understand that. I will take IT to the dealer and Get IT programmed and fitted. But What I dont understand is wich Number on the Sam unit that is the part number? LU, SW or HW?
Old May 28, 2018 | 08:00 PM
Patrick Fotsa's Avatar
2011 ml 350 4 matic
Rear SAM replacement
I’m have to change the rear Sam of my MB. I am confused between the ZA,HW,SW and serial number. Which one should match the new SAM I have been told I cold get a compatible one with my VIN NUMBER 4JGBB86E39A468568
but I don’t know where to check..could someone help?
