2014 E550 4MATIC - Vibration Issue
Old Aug 30, 2017 | 11:23 PM
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
This problem happened all the sudden.
Car is in shop with tech. But they still couldn't find whats causing this issue.
Tech has checked, Engine mount, tranny mount, LSD, tires and alignment. All these are working fine, no issue.
Here is the symptoms.
It vibrates more as speed goes up.
It still vibrates when going slow, but not very obvious.
It usually happens when car start torquing up.
Car drives powerful, no power loss.
And I test drove it in circles.
When going right in circles, I heard something is knocking constantly.
Its like wheel/tire rubbing on the ground unevenly.
When going left in circles, no issue.
Here is the weirdest part !!!!
The vibration will be gone after i straighten steering wheel from going right direction for a short while.
But vibration will come back shortly after speed going up about 70kph.
I really have no clue whats causing it.
I believe is something small. but need to locate the issue.
Old Aug 31, 2017 | 06:08 PM
iridium18's Avatar
2023 AMG GLE63s, 2017 AMG SL63, 2024 Sprinter, 1958 Chevrolet Corvette
coocoobeex - had a similar problem (not in a MB) ... was the opposite side front sealed wheel hub assembly - when turning to the Right, the forces load up the Left Front wheel - when turning to the Left, the forces load up the Right Front wheel
My 2 cents .. hope it is as simple as that for a fix
Steve
Old Aug 31, 2017 | 09:54 PM
cocobeex's Avatar
Steve
Thank you so much for help!!! this could be very possible cause of my vibration issue.
I will have tech check again on wheel hub assembly.
