M113 swap, looking for DAS / AAM/ 722.6
Old Nov 8, 2017 | 03:47 PM
bdub03's Avatar
72 280SE
I've been doing a bit of digging and decided to go with a M113 5.0 out of a W163 only because the DAS is a bit simpler. Pulled a motor and harness yesterday to start my project but am puzzled by a few things.
I know the MB world is completely unique in that most folks do not mess with wiring and re-coding but I'm up for the challenge and would LOVE to document it for other adventurous folks.
1. I've been reading that the ML500 engine MUST be mated to a 722.666 (500 final drive trans). Is this true or can I recode the TCU? I am planning on using a 2wd Trans out of a CLK43 /S430 since the AWD output shaft won't work for my application.
2. For complexity and DAS coding, is it better to go with the <01 DAS or should it not matter? I know the DAS module moved from the AAM to under the dash in 01. Better to go with an earlier setup? I am planning on snagging an immob chip and attaching to my 108 fob.
3. Can I run 430 electronics with the 500 engine? This would solve the the 430 Trans final drive concern.
Time to pickup a Star Diag or think I can do all of this myself and pay a tech for the rest?
Thanks again and look forward to hearing from some ML GURU's!!!
-Brian
