209 CLK-Class Technical Bulletins as of 5/8/04
1 Post
1997 Toyota Tacoma 4x4
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
In order from newest to oldest:
-Leaks at the internal steering lines of the control head connection and/or steering gear housing
-TeleAid runaway (repeated TeleAid calling)
-Soft top will not open or close
-Noises in the exhaust system
-Audio mutes
-Model Year 2003 engine control unit software update
-Parktronic triggers without obvious cause
-CLK500/CLK55 engine fan runs constantly
-Production date up to and not including 10/03 Fuel filler cap
-Intermittent wiper function software change, as of MY 03
-Wiper blades, improper wipe
-Verizon preferred roaming list (PRL)
-Entering navi destination not possible with CD-ROM DCA6 or DCA11
-MY 04 speed sensitive power steering inoperative
-CDs played on both sides not always ejected
-MY 2003 CLK500 engine noise
-Check Engine light with DTC P2003
-Clock inaccurate
-Erroneous Parktronic activation
-ESP with fault codes C1140 and/or C1145
-Corrosion of weld at sealing flange of windshield and rear window
-Leak at steering rack connection
-Tail Lamp bulbs burn out
-MY 2003 wiper blades noisy
-MY 2003 sliding/pop-up roof reverses
-MY 2003 front door lock knob
-CD changer skipping, not recognizing magazine, radio states "No CD changer"
-Audio mutes
-Clock inaccurate
1 Post
Originally posted by RJC
Great info. Thank You
Have you had any experiences with the puling to the right issue?
Sounds like more of a generic alignment or tire issue. What has already been done to try to resolve the pulling?
Seems like this has been an issue with some 03 and 04 models, especially 209's and 211's. Most have had alignments and some with the "bolt kit". Mine was aligned w/ the kit and is better but still pulls (follows road crown), this seems to be about the same result for most of our members. Most also have suffered premature tire wear including feathering/cupping of the outer edges of the tires.
08 E320 Bluetec
My 04 CLK 55 pulls to the right just a hair. It's a problem that I can live with. I would try the bolt kit but if that didn't solve RJC's problem I think I will leave well enough alone until some other fix is found
