A week ago it was a different message "MEASURE IOD CURRENT"
now it has switched to IOD current error
Its on a W166 GLS550 2017. I have been tryign to troubleshoot it, removing fuses one at a time, nothing seems to clear the error, which makes me think it may be coming from something 'always hot'
The draw as I switch ignition off is around 10 amps (which is the same as similar car I have with no error) but once all the can busses switch off, the draw goes down to zero
I can find no reference to this error in google and when I hook up to star diagnosis, none of the modules make any mention of this error. I have checked every module and parameter and cannot even see which module is sending the message to the instrument cluster
Finding the fuse was a false alarm. The 251 fuse was for the front SAM but the front SAM was producing this message, so the 251 fuse was simply unplugging the diagnosis of the message
After spending almost 2 days testing all the circuits and modules, I was left with just the SAM itself. I had only replaced this recently with one from ebay described as 'NEW'
So bought another one SAM, installed it, updated SCN coding and the message has gone
Seems it was the SAM all along. Hope this saves someone else the troubleshooting headache
