Snap on tool box ad tools for sale
Old May 24, 2018 | 11:34 AM
somebodytoo's Avatar
e320
First off. didn't know where to post this so apologies if in the wrong section.. Could not find a category for tools for sale ?
Kr660b with 7 drawer side box and side cabinet with 2 drawers and expandable to add drawers.
Mercedes Tech for lat 30 years and retiring from the business
Quite a few specialty tools and large inventory of Snap on , Matco, Mac, Hazet , Stahlwille and other miscelaneous.
See Inventory list.
List compiled and then estimated total cost based off of Ebay completed sales listings for used tools. If you want to do the exhaustive research and calculations I am positive you will come up with about the same price and maybe more.
Some miscellaneous items I did not even add in the total. Harbor freight pliers, T torx handle drivers, screw drivers. Sealant, o-rings. Hose clamp kit, heat shrink,solder, sanding and grinding discs, probably forgetting some things.
Total comes to $6000 just in tools. Based at about 30-50% off of new.
Total with 2k tool box $7500 for the whole package.
Text Rick at contact number down below if you are seriously interested in taking a look.
Have MB spring compressors available as well being sold separate.
Also considering selling my website if interested.. www.mobilembzspecialist.net
Only trade considered will be a 25 ft. or larger travel trailer of equal value
Please text RIck at 714-318-8491 i currently live in Temecula Cali.
Inventory list:
Snap on tools.
Standard length Ratcheting Box open end wrenches. 8mm to 19mm set
Standard length Box open end wrenches. 11mm to 18mm set
Box ratchet wrench 12mm-13mm
Short 7mm - 19 mm wrench set
21mm wrench
22mm wrench
24 mm wrench
27mm wrench
32 mm wrench
Flare wrench 9mm-11mm
Flare wrench 10mm-12mm
Brake bleed wrench 9mm-11mm
10mm to 19mm Crows feet
1/4" deep chrome sockets 5.5mm -14mm
1/4" short chrome sockets 5,5mm -14mm
3/8" deep chrome sockets 11mm-20mm , 21mm , 23mm
3/8" impact swivel head 14mm 15mm 17mm 19mm sockets
3/8" chrome socket
1/4" 13mm swivel socket
1/2" to 3/8" adapter
1/4" to 3/8" adapter
3/8" to 1/2" adapter
1/2" swivel head impact sockets 17mm,19mm,24mm,22mm
1/2" impact 27mm 30mm 36mm and 46mm sockets
1/2" impact 30mm deep socket
1/2" 10mm 12mm and 17mm Allen sockets
3/8 " Allen head sockets 6mm -10mm
3/8 " long ball ended Allen head sockets 8mm 10mm
1/2" 12 pt, spline torx 10mm,12mm long
1/2" 12pt. spline torx 10mm short
1/4" torx 20,25 and 30 sockets
1/4" 4mm and 5mm Allen sockets
3/8" extensions 3", 4", 6", 8" swivel head
3/8" extensions 3", 6", 8", 10" standard end
1/2" extension 5"
1/2 " swivel head ratchet. (long)
3/8" swivel head ratchet
Needle nose pliers long and short
Knipex long handled dikes
Standard wire cutters
Pwz1 adjustable pliers wrench
Bearing race puller CJ950
1/2" torque wrench TQFR250
3/8" torque wrench QJR2100D
Air chisel hammer
Pickle fork and 4 other chisels with a cutter.
Air drill
Die grinder
Air nozzle gun
Large straight punch
Small straight punch
Butane Soldering torch
Tap and Die set TDM117A
Vacuum gauge
Exhaust pipe chain cutter
Bump starter
Matco Tools
Ratcheting box end wrenches 17mm 18mm 19mm
Ratcheting box open end wrench 18mm
45 deg. open ended 16mm wrench
90deg air grinder
Compression and lead down tester
R12- R134 leak detector
Miscellaneous tools:
Hazet. 1/2" torx for cylinder head bolts
Hazet splined socket or Diesel fuel delivery valve removal
24mm stahllwille wrench
Drive line wrench 4550-1
Schrem 2 arm jaw puller 000 589 88 33 10
Pitman arm puller
Tie rod end pullers (2 Sizes) 140 589 00 33 00 and 124 589 03 32 10
Radiator hose hook removal tool. medium and long
Fuel pump locking ring removal tool for GL x164 and others.
Air Lift coolant bleeding kit
Sears timing light
Various large and small screw drivers. Flat and phillips. (Did not include in Price estimate. $100 worth or so. )
Large medium, small Channel Lock Pliers
Button removal tool for panels
NSK micrometer
75 n different Allen wrenches and 2 flip out sets
1 set long ball ended Allens. 3mm-10mm
Tire plug kit
Mac feeler guage set
Picks
Razors
Pen magnets
Pocket screw drivers
Wire brushes (hand held and for die Grinder)
Rat file with handle
Ball hammer
Large mallet hammer
Tape measure
Small MB Grease gun for door hinges
Hydraulic Pressure gauge head
R12 / R134 can tap
Large and small Rivet guns and rivets
Air operated Rivet gun
Numerous cut off wheels arbors and sanding discs
