SRS Fault B1010 after spilled coffee in rear seat
Old May 30, 2018 | 01:18 AM
ChintzyButters's Avatar
W203
SRS fault after large coffee (triple venti whole milk vanilla latte) spilled in back seat, most of it fell through the seat belt's recess hole. I removed the seat cushion and noise dampening insulation and dried the parts. Liquid was found puddled around a cable connection, and metal cylinder attached to the seat belt. I believe that's the pretensioner. The seat belt part number that was drenched is 2038600269 Gurtschloss Gurtlasche Schloss Seat Belt 95018.
I was able to read the DTC code and I was also able to clear the code.
My question is, with the code cleared and no new codes generated, should i undertake any additional testing of the parts or does the on board computer perform adequate diagnostics on its own?
MB Model: W203 2002 C240
The DTC code that was cleared showed the following:
B1010
The ignition circuit with component R12/6(Left rear ETR ignition squib) has Short circuit to ground.
DTC Status:
Stored
Old May 30, 2018 | 09:33 AM
bbirdwell's Avatar
Veteran: Army
'99 and '05 E55 AMG
Code is cleared and not "current". You should be good to go using the on board diagnostics.
