what does this error mean 3548 the on-board power supply voltage is too low
Old Dec 23, 2018 | 05:18 AM
Yazeed Ayasra's Avatar
W204 2008
i have this error on my car, after many days searching the web, i only found one person who encountered this issue "here on MB world" with no solution for him,
normally the car would send an error saying that the battery voltage is too low, what does the "on-board power supply" mean?! where is this power supply?
note: i changed the battery & the ECM/ECU with no luck of resolving this error,
any help would be highly appreciated
Old Apr 16, 2019 | 10:18 AM
Kebowers47's Avatar
001 s600, 94 sl600
Unhappy on board power supply low means?
I suggest you contact MBZ technical support. They should be able to explain where the 'low voltage' message is being triggered. It can be from a high resistance external connector, the power connector to the particular circuit board, a defective voltage regulator on the circuit board, or many other contributors. Many electronic components are very sensitive to supply voltage and will overheat if voltage is too low.
Please share when You find it!
