C32 Hesitation
What I'm referring to is the hesitation or "flat spot" at around 1500 rpm. Although it is not as pronounced in "W" mode, I am not convinced that it is transmission/torque converter related, as some other owners have been told.
If I were to drive this car without knowledge of the extreme computerized control, I would say that this is a fuel mapping / sensor problem. Feels like there is little or no signal to the injectors (no fuel) when certain conditions are encountered - approx. 1500 rpm, light load, and slightly increasing throttle application. A couple of times I have continued pressing the pedal slowly and it actually slowed... then sudden acceleration!
Today I actually heard what sounded like a minimal lean backfire from under the hood. Could this be related to the vaccuum to boost transition? Or is it possible that in the quest for mileage and emissions, that the fueling at this point is simply too lean? If so, is this serviceable by a Tech or is it an issue of swapping out a sensor(s) and hoping for the best?
I will be taking to the dealer very soon, but wanted to get some input first.
Thanks,
Was hoping for opinion from mbtech208 on this prior to service visit.
