W209 (CLK) Wiper troubleshooting Question
Old Jun 24, 2019 | 01:59 PM
chewtoy's Avatar
2009 CLK 350 Past: 2007 C230
Question W209 (CLK) Wiper troubleshooting Question
Hi,
Have a new to me CLK 350 with dead windshield wipers. I understand the process to diagnose is
1: Check fuse + power @ fuse box
2: check power @ Wiper Motor
3: Check Wiper relays
4: Check column switch
Question - How do I check the relays? There are two.
And how do I test the column switch?
Thanks!
Old Jun 25, 2019 | 01:17 PM
chassis's Avatar
2017 GLE350 4MATIC
A way to see if you have a bad relay is to buy a new one and see if it fixes the problem. Not strictly a test, but ruling out by process of elimination.
Another suggestion is to use a multimeter on the relay contacts in the fuse box/SAM. However I don’t know if some relay contacts need to be in place to test the circuit so this may not be 100% successful.
Can you pull the power connector off the motor and access the contacts with a multimeter?
Checking other items requires the wiring diagram to see where cables are terminated. Or pull the harness off the switch, if accessible, and use a multimeter.
Common theme here is a multimeter. I like my old Fluke, purchased about 10 years ago but it is the decades-old design.
Old Jun 27, 2019 | 12:13 PM
chewtoy's Avatar
Thanks Chassis, I'm going to check for voltage @ the motor and will report back.
