BLEEDING BRAKES CORRECTLY? BROKEN MC?! HELP!
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
I have a 2014 e550. I recently picked up rear AMG calipers with rotors. I wanted my calipers painted so I removed all four. *I should have clamped the brake lines but I didn't. I said, I'll just let it drain out since I am going to be bleeding all 4's anyways. *whole system ran dry. finally 3 weeks later calipers are ready for install. installed them and here are the events that happened exactly.
1. poured oem brake fluid into the reservoir until the level became steady topped off
2.connected the power bleeder to the reservoir- schwaben
3. pressurized the system to 18psi- although later on I found on xentry WIS or w.e that ur supposed to do 2.0 bar/30 psi
4. bled starting from farthest>closest to the MC.....I ran so much fluid through that there were absolutely no air bubbles
5. made sure all the bleeders were tight
6. I get in the car and pumped the brakes a couple times....I don't recall if I did it slowly and soft or hard and fast...NOTE: the MC was dry for weeks...I should have slowly pumped the pedal right after pouring fluid in before doing the pressure bleeder.
anyways I spent about 3 days trying to figure out why the pedal doesn't get hard and and wont hold pressure. I thought there was still air in the system...maybe in the ABS? MC?
I bled it prolly 100000 times...no air bubbles was coming out of the bleeders...I had a clear hose connected to each bleeder with its own bottle. activated the esp on xentry-which actuates It for 5 seconds..did It a couple times....no change...I don't even think it was doing/bleeding anything...
bled the MC by disconnecting both lines and hooking up them plastic fittings with tubes going back into the reservoir...slowly pressed and depressed the pedal prolly 200+ times lol....I didn't wanna remove the MC as I thought it would be the same thing as the real way of bench bleeding by putting it on a vise and pushing it with a screw driver
proceeded to bleeding the brakes again after this....SAME THING
PEDAL KEEPS SINKING TO THE GROUND
IT DOES HAVE SOME PRESSURE TO IT THOUGH WHEN PUSHING
IT ONLY BUILDS PRESSURE WHEN I PUMP IT HARD AND SUPERFAST BUT AFTER ABOUT 5-10 SECONDS THE PEDAL GETS SOFT AGAIN AND ALL THE DOWN TO THE FLOOR
I DIDNT THINK IT WOULD BE THE MC.....CAR HAS 20K MILES AND VERY WELL MAINTENED...I KEPT INISTING THAT IT WAS MAYBE AIR STILL IN THE SYSTEM LOL
after days of troubleshooting and countless bleeding 2 man pump and release/ power bleeding...no luck
no leaks on any of the calipers
now I ruled out its gotta be the MC...I must have blown the seals somehow in the beginning since I let it run dry
oh and i noticed...i had my buddy step on the brakes while i was watching the pistons and the rears were barely compressing... the front u can see the caliper and rotor move a bit...the rears yes piston was moving but not as hard...its like theres only little pressure..the only time the rears would clamp hard is when i pump the brakes vigorously and fast then it build up pressure and i hold it. i let go and after a couple seconds it soft again
LASTLY JUST EARLIER TODAY....LAST NIGHT WHEN I PARKED THE CAR....FLUID LEVEL WAS ON MAX....CLOSED THE RESERVOIR CAP...MORNING I GO AND OPEN THE CAP AND IT WAS SO FULL IT WAS ALMOST LEAKING OUT OF THE RES...PUMPED THE BRAKES A COUPE TIMES AND THE FLUID WENT BACK TO MAX LEVEL....10-15 SECONDS LATER...FLUID STARTED TO COME BACK UP AND LEAKED OUT SO I PUMPED IT TO GET IT BACK TO MAX LEVEL AND THEN I JUST CAPPED IT.....WEIRD SHHHH HUH?! WTF
story of my life....never thought i would have so much problems on just bleeding the brakes...sorry if i repeated myself but im just trying to explain what is going on exactly cuz this has been PITA and consumed 3 days of my time lol...if would have just clamped the lines...it would have been cake...
please let me know what you guys think?
i will be ordering a new MC and i hope it is the problem...i have tried just about everything..if this doesn't fix it then idk...lol
BRAKE EXPERTS
whats the correct way on using the power bleeder...i read somewhere that you should still have someone pushing the pedal while its pressurized when bleeding....if that's true what is the sequence? while it pressurizes- pump and hold then bleed????
and of course when i get the new MC i will bench bleed it
as far as ABS bleeding...i have XENTRY but all that's on the actuations for ESP is high pressure and return flow pump/ left rear pressure regulating valve pressure/ SBC hold
theres isn't a button where it says abs bleeding procedure or w.e
any help would be greatly appreciated!!!
THANK YOU SO MUCH!!!
BRAKE EXPERTS
