Question about CEL Code
Old Jul 14, 2004 | 11:34 PM
EiknujZneb's Avatar
1991 300E
OK. So I finally figured out how to get the Check Engine light after you fix the problem (disconnect the battery, thanks for saving me money guys heh), and realized the light wasn't goign out. So I took it in to have the codes checked again and the dealer said it was giving "implausible signal to EHA" or something, using a reference I'm assuming the real code was "current to EHA" because thats the closest match i could find on the list of codes.
Is there a common problem or malfunction that causes this code? Or am I going to have to get it fully diagnosed by my mechanic? I can fix most things if i know what to fix, so I would be saving a great deal of money if i could only figure out what was wrong.
Thanks for any help
-E
Old Jul 15, 2004 | 06:05 AM
teky's Avatar
well what was the code, what car is it,what year,what engine, what is EHA i dont have it listed?? in the fault code book
Old Jul 15, 2004 | 11:30 PM
EiknujZneb's Avatar
1991 300E
Sorry guys, must have been reading the wrong forum when i posted.
The car is a 1991 300E m103.
EHA - Electro-hydraulic Actuator
Old Jul 17, 2004 | 04:26 PM
Jer's Avatar
Jer
1994 E320
The EHA is a fuel trim device mounted on the fuel distributor. It is one of the the few electronic servos of the KE injection system. The wires to the EHA might be frayed, or the EHA has an electrical fault and needs to be replaced.
