Faulty ride height sensors/bad ABC module??
Old Oct 9, 2019 | 09:20 PM
BrentWa's Avatar
S55 (4), S600
Hey gang, I have a '03 S55 which is pretty much mint but when I climb hills afterwards the left rear drops. Now from experience (I have years don't snow me bs) I know that issue is not a shock tower or leaking valve block... So I took off the front tires 2 c what the ride height sensors were up to and check for ground and voltages. Well the ground was good but I got 5 v. reading on the front left and '0' volt reading on my front right BUT OEM readings are supposed to be 2-3 v. So put 2 + 2 together and that spells short somewhere in my book. Most likely a bad ride height sensor which is shorting out. The problem is my Euro mech tells me they're separate and NOT on same wiring diagram so how could I have gotten 2 bad readings?? Now points to a bad ABC module! Ideas??
Old Feb 5, 2021 | 07:52 PM
turbonos7's Avatar
'05 S430, '05 S600
Did you ever figure this out?
