Who is good at coding? ECU -TCU 7G-tronic to 9G-tronic
Old Feb 23, 2020 | 06:18 PM
Joseph~'s Avatar
2008 R320 CDI 4MATIC
As stated in the title.
Who is good at coding,?
Looking to replacing a 7G-tronic to a 9G-tronic.
Thank you
Joseph~
Old Feb 23, 2020 | 06:52 PM
chassis's Avatar
2017 GLE350 4MATIC
Sounds like an expensive and time consuming project. Can you share something about the motivation for this?
The only OM642 engine + 9G-Tronic transmission combination is the GLC 350d. You might think about using a transmission and TCU from a part-out GLC 350d. A question will be, with the later model OM642 in the GLC paired with the 9G, what will be required with your older OM642 to make the swap? Engine changes will also be necessary, specifically spark, fuel and possibly cam position mapping. Likely also EGR and turbo control.
Keep us posted.
Old Feb 23, 2020 | 09:23 PM
Joseph~'s Avatar
Keep us posted.
FWIW.......
What I have learned is, in the EU the 0M642 where the first engines with the 9G, in 2013 was the first year MB offered this in an E350 Bluetec. To maximize mileage, that what was said in PR. Not offered in the US.
Physical / mechanical should be for the most part a direct swap fit, They are backwards compatible.
Motivation? No different than modifying US vehicles. People do this all the time, to improve what they have. I did a 1986 6.2NA GM diesel to a 4L85E transmission, running an independent controller,. The vehicle is a 1986 5/4 ton pickup with a utility body,
Expensive? What is considered expensive?
You can find a pulled 9G with low mileage less than 20K for less than $2,500.00 and that is from a salvage yard. I performed all the labor..
The more important issue is programming.
I am not that familiar with the programming for MB, but I will be.
Regards
Joseph~
Old Feb 25, 2020 | 02:45 PM
Joseph~'s Avatar
For those who are interested, located the following video, shows the procedure to program a 9G-tronic;
As my search continues..........
Regards
Joseph~
Old Feb 25, 2020 | 02:51 PM
Gazwould's Avatar
S204 C250 CDI Sport
Good luck !
Old Feb 26, 2020 | 03:26 PM
Joseph~'s Avatar
Have located the software that is used to do programing on all MB vehicles{and it is NOT by MB] including programing FOBS, EIS, virginizing, read /write all modules.
Regards
Joseph~
Old Feb 26, 2020 | 04:08 PM
pmercury's Avatar
member
CL
Regards
Joseph~
Best way Is to add the SA code to VDOK then SCN online
then the trans is Registered officially at MB as belonging to the car
at least, that is how I do it
