Camber Kits
Originally Posted by devanwon
WHERE DO I GET CAMBER KITS FOR MY 97 E320. ANY HELP THANKS!
Try www.k-mac.com.au
or do a search...there is a member on here that sells them for considerably less $.
Hello,
I have been making adjustable Camber Arms for Mercedes W2101, W210, W208, W202, W203, etc for over a year now. They use very high quality rod ends with Kevlar/Teflon bearing races and DOM steel tubing for the tie rod. I have about 60 sets on all sorts of different Mercedes models running around USA.
Inserts to make them fit the various applications are made out of Stainless Steel to limit corrosion. Cost is $260 shipped.
Let me know if your interested it usually take about 2 weeks to get an order out, as I machine and build these at my home after work.
Jeff
Jeff
MY CAMBER AFTER ALIGNMENT CAME ABOUT
.75 DEGREES OF FOR BOTH FRONTS AND 1.0
DEGREE OFF BOTH IN THE REAR...DO I REALLY
NEED THESE? WILL IT RUIN MY TIRES..... I ONLY
LOWERED THE CAR 1.4F 1.3R? ANY INPUT GUYS
Nope, not as bad as mine did at 2.0 front and 2.2 rear. I am using a k-mac kit for the front and speedybenz's stuff for the rear. I would have used his stuff front and rear, but i alreayd bought the kmac kit for the front. Also play around a little with your tire pressure. I went down to 35 front and 34 rear. It helped wear a bit better.
